2010 XF upgrade to tv/sat nav
Received 3,208 Likes
All XFs came with sat nav, maybe the one you are looking at is missing the DVDs and/or needs a reset?
The DVD player for the sat nav lives in the boot, on the LHS behind a little flap.
Open that flap, press the eject button and see what happens.
Also check the glovebox and the centre console, the DVD set might by in there (I understand that for UK and Europe it's a multi- DVD set, unlike here in Oz where one DVD does the trick!).
TV is a different matter, I suspect it can be activated my someone with the correct SDD software and cable. If not, it may require a lot more work which would be fairly expensive.
Finbarr1975
09-16-2023 02:52 PM
bydand
09-28-2015 09:47 AM
