2010 XFR anything I need to know?
Hey guys,
Im back and I THINK, i may have finally found a car I am happy with . Its a 2010 XFR, at a price that works for me, its a little over the mileage i usually like to buy being a little over 90k I usually go between 60-70. But judging by you guys previously its not a huge concern.
Apart from the obvious and what I have been told on here before ( rear differential, leaking water pump, gear selector, screen and bluetooth functions, and dash leather.) Is there anything else I should have my mechanic aim to check specifically tomorrow?
Also what are the specific things to look for with gear selector?
On the carfax report it says water pump replaced so thats good, but it also says 'ENGINE/POWER TRAIN COMPUTER/MODULE REPLACED'
Does this literally mean the engine was replaced? Im not sure how that would be so on a clean title car ? Can anyone enlighten me.
Any info before tomorrow to provide my mechanic in aiding me making asafe purchase is greatly appreciated!!
PS: Anyone got experience with Reliable Protection extended warranty? Is it worth it?, Are they good?
Thanks again!!
Thanks again!!
Received 3,263 Likes
The 5.0 S/C in the XFR has a "black box" called the Engine Control Module or ECM. It is sometimes also called the Power Control Module or PCM. In most other cars the same thing is called the Engine Control Unit or ECU.
Component #2 on page 493 of the Workshop Manual, see here:
I've never heard of this being a problem component on the XFR but I can't see any downside to it having been replaced.
Apart from the things you have listed the only "problem" with the XFR is the way it chews through brake rotors, brake pads and tyres fairly quickly, so check the condition of these before you buy, and if any need replacing use that as a bargaining chip to reduce the price. I did this with my XFR and got $3,000 knocked off the price, then renewed the rotors, pads and tyres myself for $2,000.
webshark (07-16-2016)
Yes. Great car
As mentioned above brakes, rotors and tyres for sure as its not a cheap replacement
Would also have the wheels balance checked - the jag 20inch alloys are very soft and easily bent. And they run around 600usd+ each to replace - and on an expensive car a highway wobble is pretty disappointing!
Good luck. You'll love the XFR
Yes. Great car
No - don't do it on the 22 inch wheels!! Ok - just a personal pov but the 20inch has petty little rubber beyond the wheels, ride can be a bit hard on rough roads and easily dented on potholes. So I can't imagine how uncomfortable 22inch would be. But I'm not speaking from experience - there was at least one person on the forum who ran 22inch and I thought it wasn't that comfortable but search around and see
Think it depends where you are going to drive. If it's smooth and well maintained freeway then it might be fine. I live in north east USA now and the road surfaces are not great...
If I were you I'd push to negotiate a discount off the car price due to the wheel condition and buy a set of aftermarket 20inch to replace the banged up OEM ones. Many of us have done that over time / in my case as I needed a second set for winter tyres anyway. You can get a good selection for the 1600-1800 usd price point
As I say, just my opinion. Will let someone who has actually run 22inch give a real experience opinion
You could also drive the other jag they have with the 22inch on it and see what the ride is like
Depends on what kind of miles and how the owner treated the car. Did it sit out in the weather day and night? Did it do a lot of stop and go driving through pot hole ridden streets? Was all of the maintenance done on time? Etc.
I always say when you are buying a used car, you are buying a previous owner. They make all the difference in the car you are buying. And if you are buying from a dealer, it's a crap shoot because you don't get to know the previous owner until you have owned the car for a while and learned the hard way whether they took care of the car.
webshark (07-19-2016)
Yea its a tough call when buying from dealer.. From a viewing standpoint in stands head and shoulders above most other cars ive seen even with lower mileage. The same dealer has a 2010 premium, with the 22" custom rims with 34k miles for and extra 2k,. It seems like the sensible buy but it aint no XFR.. And im really not that sensible..
Has there been many owners of the S/C and R on here with over 100k miles who are running smooth and problem free?
Fuel pump
Alt
Intercooler pump..etc. are all getting up there in use.
Plus the normal wear items of Plugs and O2 sensors belts, pulleys, tensioners, diff lube and trans service will need looking into also. All that said,
THE XFR IS BY FAR THE BEST CAR I'VE EVER OWNED. Punch it from 70 to 110mph 1 time and you'll see..lol
Thank you.. The dealer actually has another XF premium there but it has 22" concept one wheels that look great. He said he would throw them in as in replace the factory XFR ones as part of the deal . Is this a wise choice on my behalf? They certainly look much nicer and the XFR wheels are slightly scuffed also.
Well I've had mine since 2014 and 52kmi, I'm now at 74kmi. I've had 2 major issues, The A/C condenser sprang a leak, and the cooling fan went out = $2700, both were covered under my extended warr which cost me $3500. I do most of my own wrenching and I can tell you the Jag is not very hard to work on especially if you get the service manual or use Jags ToPIX, but Jag service is expensive. I'd get an extended warr. if its offered, or you can set some $$ aside because if your coming up on 100kmi? The following;
Fuel pump
Alt
Fuel pump
Alt
JohnBurns
02-10-2011 11:51 AM
