2010 XFR Engine Removal
check out thread from davetibbs, there have been a few engine removals, but not sure any with tranny intact.
Yep - the only method the Workshop Manual details is to pull the transmission from underneath, separating it from the engine, and then lift the engine out of the top with a crane, which is how I removed mine.
However, it's entirely possible to remove the engine, transmission, and subframe as one from the car and lift the car up to separate them - the method is pretty much the same across all cars, which is to unbolt any front suspension (e.g. strut towers, wishbones, etc) from the body of the car, and then unbolt the front subframe from it, remove transmission mounts and disconnect driveshaft before lifting the car up. There's probably a lot of things you've got to watch for with hoses, cables, etc being fixed to the body before you can lift the car but it's definitely possible as I've seen photos of it done.
I guess it's just less common because people are more likely to have (or be able to rent) an engine crane rather than have access to the entire 2/4 post lift required to lift the car up enough that you can pull the engine out from underneath, but it doesn't make it any less valid a removal method.
kansanbrit (09-03-2020)
