2010 XFR Overheating
Hi All,
My 2010 XFR overheats at low speeds in traffic. I have hooked up an OBD reader to find the following:
- The car is capable of regulating it's temperature when driving around in the city (60 kph/40 mph). It keeps the temp at roughly 90C.
- When idling the temperature will go above 90C. I watched it go to 115C when the 'engine hot' warning kicked in. Then to 117C when the engine 'overheating message' was displayed. During this time the rad fan turned on for 3 or 4 seconds then never turned on again. At this point I shut the vehicle off and went to work.
I tried to check the fuse. The manual says location F17 for an 80A fuse. Well, there is nothing in location F17. I think it's a mistake.
My questions to you guys are:
1. What is the correct location of the rad fan fuse?
2. Any ideas on diagnosis for the overheating problem? My best guess is the fan controller if there is such a thing
Thanks in advance for the help,
Oldie
Oldie
Is there a dealer in the 'toon or do you have to go to Regina?
It is likely the fuse is not an issue if the fan will switch on. If it is now permanently inoperative then obviously a fuse is number one and maybe a relay. Maybe call your closest dealership and ask?
Also, the AC system should energize the fan if AC is demanded by the HVAC. If it doesn't then you have an electrical failure.
The cooling systems usually have a low speed and a high speed function fed by two different relays or circuits.
If not a fuse or relay then I think Jaguar would use fan controller software unlikely to be faulty.
There is a dealership here and I am booked in however, if possible, I like to fix these things myself to save cash.
The ac engaging the fan is a good tip. I'll check that out.
I'm also going to give the fan a spin to see if it moves freely.
Any idea where the fan controller and relay are? I would like to probe it with my multi meter. I'm thinking this is where the issue is.
I'd also like to check all connections if I knew where they were. Any one have a wiring diagram for this car?
Thanks,
I know exactly what you are going through. Unfortunately the fan and controller on an XF is an integrated unit that cannot easily be separated. Jaguar designed the unit to be able to a one part replacement. However the fan motor assembly is very expensive from Jaguar. I searched around and found several on eBay. Here is one so you can see the assembly and how the controller is mounted on to the fan motor assembly. The controller is the computer box at the center of the fan motor where the wires go in. You have to replace the unit as one part. This will solve your issues. The actual work to replace it is quite easy and only requires the removal of the intake tubing.
Dealer diagnosis
Took it to the dealer and they said the water pump is done. I guess the pulley has a pretty decent wobble. He tested to rad fan and controller and said that he was able to engage the fan without any issues. Im not sure how the symptoms point to the water pump. Hopefully he is right.
Well, the new water pump is in after 1500 bucks. In just driving it home from the dealership, the car seems to regulate temperature just fine. In fact, it seems to have more cooling capacity. Now when the thermostat opens, the car gets even cooler than before. Seems unexpected given the original symptoms. Will report back status after more driving.
It was an expensive job. Two of the four bolts were stuck. I hope for my sake the replacement pump is a better design than the original (for design life). I also hope they used an anti seize compound on the bolts.
Ed
Agreed. Although, I don't consider myself mechanically challenged.
I knew what the problem was going in. They had three people on the line assuring me that they need to fix the water pump because the pulley was wobbling like crazy and that the pump was grinding and growling. I'll post a video of what it sounds like and the bearing shimmy it has (if you can even call it that).
This biggest thing I'm afraid of is breaking a bolt in the block. Otherwise, I prefer to do my own work as well. Except now I have a baby that runs my life...
I've attached the updated instructable and native file.
My new fan finally came in. I was able to install it and successfully test it. Looks like the problem is solved so far. More driving while watching the temperature of the car is in order to make sure the problem is gone.
Hopefully someone can post the instructable in an area where others are located.
Thanks for all the help.
Ryan
Ryan
The wobble and rattle are not ideal however, both are so minor that I don't believe the function or reliability of the pump were greatly affected.
I certainly wasn't on it's last legs as the mechanic and manager led me to believe. I'm going to be talking to the dealership about this.
I would like to try to refurbish the pump if anyone can walk me through getting the bearing out of the housing.
I took the pump because I was upset with them and wanted to examine it. See previous post for my diagnosis. I've attached a video of it.
Ryan
Ryan
