2011 Jaguar XF console issues
I have a Jaguar XF that I was using a Bluetooth adapter Bovee 1000 that plugs into IPOD connector.It worked well for years. All of a sudden it stopped working, got hot and I disconnected it. The USB port in front now only works if something is plugged into the IPOD port which of course I can't do. Anyone know what causes this? The power port does not work and the whole console is kinda flaky. Car works flawless and only has 37,000 original miles. Do you recommend me fiddling this myself or take it to Jaguar?
Yep check for water under the carpet. Mine was coming from the condensate drain at the bottom of the climate control unit. Killed the bluetooth and ipod modules.
Dayzel108
07-31-2014 12:11 AM
