2011 X250 S/C Running Rich Both Banks
Seeking your wisdom on the order of troubleshooting here.
2011 XF 5.0 S/C with 90K miles is throwing the following codes common on this forum:
The current troubleshooting ladder, testing the effect on each step is:
Given the other goings on here and the strange readings from the O2 sensor (which seem to sit at ~0.75 at idle but plunge to 0.01 under load), I'm starting to wonder if I shouldn't start heading in the electrical issue direction. I appreciate any thoughts y'all have.
- P0172 - Bank 1 rich
- P0175 - Bank 2 rich
- (Intermittent) P0101 - MAF Sensor circuit range/performance
- After clearing the codes, P0172 and P0175 came back after a few short drives, but P0101 only reappeared a day later, accompanied by a violent bucking between 2,000 and 3,000 RPM.
- LTFT is about -5% on both banks at steady state
- Car will go into Performance Restricted mode somewhere above 4K RPM when these codes are present, which I understand to be normal
- Clean MAF & run some cleaning fuel additives
- Smoke test from intake
- Replace MAF
- Replace Battery
- Investigate injectors & fuel rail
Good Evening All,
I ended up replacing one of the MAF sensors, and this seemed to solve the issue for several days, and no additional codes popped up as even pending.
However, today the strange surging at light throttle reappeared, and the engine light came on again with a P0102 code -- voltage out of bounds.
Is it more likely the new MAF sensor is bad, the second un-replaced MAF sensor has since died, or that I have an underlying electrical issue?
Appreciate any thoughts, thanks.
Good Evening All,
I can only see downstream O2 sensor voltages in realtime. I returned the cheap Chinese MAF sensor and replaced it with a remanufactured BSE unit. Cleared the codes, it cleared the permanent, and the car has run several cycles without throwing additional pending codes.
Comparing the pins of the Chinese unit to the remanufactured OEM, the pins seem a hair shorter and are definitely flatter, makes me wonder if the harness wasn't making good contact.
mhamilton
10-15-2017 06:33 PM
bfsgross
10-23-2011 08:33 AM
