2011 xf 5.0 water pump
I replaced the water pump in my 2011 xf 5.0 v8. When I took it out there was a black hose with a little 90 degree plastic fitting that went right into the water pump by the pulley. I have tryd everything to figure out where to get one and still no leads. Hopefully y'all can help out thanks
Received 3,226 Likes
Having just replaced this hose on my (out of warranty) 2010 5.0 XF, I can tell you why you can't find the pipe - it's been discontinued!
They've changed the design of the pipe as well as the larger pipe that goes from the thermostat to the metal pipe above the throttle body. I'll try and dig out the invoice later and get you the part numbers.
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
mikimogo
09-14-2015 08:34 PM
chatmanx
09-11-2015 07:17 PM
