2011 XF Premium
Since they were first used on a few original equipment applications in 1985, friction materials that contain ceramic formulations have become recognized for their desirable blend of traits. These pads use ceramic compounds and copper fibers in place of the semi-metallic pad's steel fibers. This allows the ceramic pads to handle high brake temperatures with less heat fade, provide faster recovery after the stop, and generate less dust and wear on both the pads and rotors. And from a comfort standpoint, ceramic compounds provide much quieter braking because the ceramic compound helps dampen noise by generating a frequency beyond the human hearing range.
Another characteristic that makes ceramic materials attractive is the absence of noticeable dust. All brake pads produce dust as they wear. The ingredients in ceramic compounds produce a light colored dust that is much less noticeable and less likely to stick to the wheels. Consequently, wheels and tires maintain a cleaner appearance longer.
Ceramic pads meet or exceed all original equipment standards for durability, stopping distance and noise. According to durability tests, ceramic compounds extend brake life compared to most other semi-metallic and organic materials and outlast other premium pad materials by a significant margin - with no sacrifice in noise control, pad life or braking performance.
Basically I think the evolution of ceramic pads is an engineering improvement over past materials and they don't eat rotors they save them.
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
scottjr1 (07-23-2012)
Hi, Does anyone know the secret to getting the courtesy lights to work when the car doors are opened? I've tried the 2 second instruction but it doesn't seem to work and I don't get a notice in the message window. Obviously I'm doing something wrong.
Also has anyone's wife complained that the seats are too hard, like planks of wood?? Personally I find them comfortable.
Thanks.
scottjr1
Thanks.
scottjr1
![Icon Boat](https://www.jaguarforums.com/forum/images/smilies/icon_boat.gif)
scottjr1 (07-26-2012)
wannabebuyer
10-01-2015 12:34 PM
vacolorito
09-25-2015 09:29 AM
