2012 xf coolant leak
I've been having a coolant leak problem. Took into a shop and they replaced the crossover pipes. The leak stopped for a few days and now back again. I attached a video of where I see it leaking from and not sure whats going on here. Underneath from passenger side. Any ideas??
Ran into a coolant leak on my '18 XF at 45k mi. There was a pinhole leak near the reservoir filler cap that was easy to locate, thanks to the white smoke it would produce after the car had got up to temperature. It also left coolant spray along the adjacent face of the engine. Sadly, I can't quote you a repair bill as it was covered under warranty, but I believe a section of piping was replaced. Good luck!
mpasiuk
24
03-14-2022 10:12 PM
showstopper9ren
XF (X260)
03-12-2021 04:43 PM
