2012 XF - Incorrect Fuse Box?
I was looking at the fuse box in my trunk to do a fuse tap for an active exhaust I am installing. I opened the owner's manual to look at which fuses were used for which electrical system(s) in the car, so that I can fuse tap into one of the least complex system (TPMS, Supplementary Restraint System, Etc.)
The "Fuse No" mapped to the corresponding "Circuit" (Electrical System) in the owner's manual is completely different from what I see in my car. This raises two concerns:
1. Should I be worried that my Fuses don't line up according to the book? Or is my owner's manual not in sync with the Fuse Box in my car?
2. I can't narrow down which fuse supports which system, there are multiple 30A, 25A, 15A, 10A, and 5A amps, they are all in different fuse holders compare to the manual. I wan't to ignore fuse tapping into the complex systems.
Anyone run into this issue? Attaching pictures of the owner's manual and fuse box.
Received 3,226 Likes
Jaaaggg (02-18-2016)
Are you looking at the right fuse box? Jaguar calls these smart junction boxes, they act as a module as well, not just a power junction with only fuses. On the XF, there will be 3. One in the engine bay, one inside the cabin which is the central junction box, and the rear which is the auxiliary junction box. They give different names from SDD, to Topix to the parts catalogue. I've contacted jaguar UK about that many many times. With that said I've never looked at the owners manual for fuse location, never come across this issue. Unfortunately I'm off work for the rest of the week, I wouldn't be able to tell you fuse location until Monday my time, I'm in New Zealand, so that'll be Sunday your time.
And thanks, I'll look forward to your update.
Ok here is the info coming from Topix under your VIN, from the handbook. This is for the fuse box in the trunk. Let me know if you want the other fuse boxes too. If anything looks different, double check. Otherwise, I will have to go into the wiring diagram to get further info, which will take a little bit more time, and I can only look it up from work. Let me know, hope this helps.
Fuse
No
Rating
(amps)
Fuse
Color
Circuit
F1 30A Pink Air blower.
F2 30A Pink Electric parking brake.
F3 - - -
F4 - - -
Fuse No Rating
(amps)
Fuse
Color
Circuit
Fuses
195
F5 - - -
F6 - - -
F7 30A Pink Heated rear windshield.
F8 30A Pink Audio system (Premium audio only).
F9 - - -
F10 - - -
F11 - - -
F12 - - -
F13 - - -
F14 5A Tan Telephone.
F15 10A Red DVD, Satellite radio.
F16 - - -
F17 - - -
F18 - - -
F19 - - -
F20 - - -
F21 - - -
F22 - - -
F23 - - -
F24 - - -
F25 25A Clear Fuel pump.
F26 15A Blue Audio system, Portable audio interface.
F27 10A Red Navigation, Voice recognition, Touch screen.
F28 - - -
F29 - - -
F30 25A Clear Driver’s door module.
F31 25A Clear Front passenger door module.
F32 - - -
F33 5A Tan Tire pressure monitoring system.
F34 - - -
F35 10A Red Supplementary restraint system.
F36 - - -
Fuse
No
Rating
(amps)
Fuse
Color
Circuit
F3 - - -
F4 - - -
Fuse No Rating
(amps)
Fuse
Color
Circuit
Fuses
195
F5 - - -
F6 - - -
F9 - - -
F10 - - -
F11 - - -
F12 - - -
F13 - - -
F16 - - -
F17 - - -
F18 - - -
F19 - - -
F20 - - -
F21 - - -
F22 - - -
F23 - - -
F24 - - -
F28 - - -
F29 - - -
F32 - - -
F34 - - -
F36 - - -
Different fuse box in boot
Hi Jaaaggg
I have exactly the same fusebox in my boot (Jul11 XF 2.2D) but the info provided by JBzXJ40 does not help because the fuse layout is clearly different. I want to check the 30 amp fuse for the EPB (park brake) - it should be in position 2 according to my owner's manual and JBzXJ40's info but position 2 is empty.
Did you obtain a true fuse list ?
Cheers pfj
Cheers pfj
Hi Jaaaggg
Cheers pfj
Cheers pfj
I am not 100% sure though, sold the 2012 XFR.
I found it, it was for the SDARS module with part number DPLA-14C740-AA and CH22-14c340-BC, it is in one module i think it was for the bluetooth, radio and XM. I unplugged all the wires from that module, and the fuse stopped blowing, and I found rust coming out of the ports from the module. I am buying an used part from ebay.
it depends on the year of the car, mine is a 2015 and we just had the f21 fuse blow and it was a 5A type fuse. I don’t know too much about the fuses when it comes to other year models
daz440
02-24-2016 06:10 PM
juded61
02-16-2016 11:02 AM
