2012 XF map update
2012 XF map update
Just finished the latest USB map update for the nav system. Cost 199.00.
Took maybe 2 hours and change. Just let the car run and checked it from time to time. Followed the instructions that came with the USB stick.
It finished and rebooted in about a minute to the nav screen but didn't show a map. I did get a bit nervous.
Waited three minutes as instructed and then shut off car and locked it for about 30 minutes.
Restarted car and all was well!! Looks fine and I will check it out over the next few days. I don't expect any issues.
After reading some horror stories, I was nervous about the update. Had the USB for about 1 month, before I got up the nerve to actually do the update.
I know some say it's too expensive and the maps are outdated quick, but the version on the car was the original, when I bought it last year, and I figured....why not?
So if you do it, just follow the instructions and you should be OK. 👍🏼
