I got these coming in
got them reaaallly cheap with coupons and free this and that and percentage discounts from carid...
any experience with these? what about proper break in? where i live there's not alot of open road to get up to 45 and down the way they want to do it and if there is you do have to do alot of breaking to get to that kind of open road..
v
I used those on the rear of my car, am pretty impressed. especially with the low price
Used Akebono on pads on the front, car stops nicely
Originally Posted by Six Rotors
Today I removed all the plastic undertrays so I can rustproof the metal underneath-----brake pipes and battery feed on the passenger side and fuel pipes on the drivers side.
My car does not have the undertrays, been looking for them used, seems a bunch are missing or torn up (350 new no way) Any thoughts about what they do and how necessary?
Regarding the undertrays, I really have no Jaguar specific information. From my RX7 Turbo II and Twin Turbo days, I know that the engine under tray made a significant difference to engine cooling, both coolant and under hood temperatures were measurably increased when the cover is missing. Other covers further down the car provide protection against smaller road hazards and also reduced corrosion in harsh climate. Lastly there has to aerodynamic implications but I never investigated the effect of their absence-----my Twin Turbo was good for 165mph.
My Vanden Plas has all the undertrays. I did buy a 2005 VDP last year which had damaged undertrays and severe corrosion of the brake pipes at the back. I sold it on.
So many cars have similar covers and I find it hard to believe they serve no useful purpose.
Well time to update. Today I had the car safetied so I can get plates and sticker. Also did a 4 wheel alignment check resulting in front toe adjustments on both sides. I will get the insurance lined up tomorrow and on the road next week. Yes I borrowed the plates off my 2004 Vanden Plas!
Awesome! Your very lucky to have a 2012 Jag v8 in today’s day as it’s so rare to find on the used market, well rare to find one that’s good enough and trustworthy to buy.
$60 for an oil change! I’m paying $400 at the *******s!! They did repair couple of my things for free like the coolant pipes and tank, as well as they did injector cleaning for me but they r definitly making $$$ off of me. Recently I got misfire codes and turns out a couple of my fuel injectors got clogged with gunk. Seems like it might be worth it running fuel system cleaner once a while maybe at 100K KM as I’m at 160K. The dealership said they used their tool to pressurize cleaner straight through the injectors and then added the additive to my tank. Car was driving bad after that too but was getting rich codes, that’s when we reset the engine adaptations which improved the drive. After finishing the tank of gas with additive now it’s running better. I was using petro ultra 94 before but switched to shell v power 91 now as it has no ethanol but honestly don’t know if it will help.
If they replaced the coolant pipes and coolant tank you got a good deal. Depending on which coolant pipes were replaced?.
I am not sure which coolant lines if any have been changed ,or if the water pump has been changed. It has had the radiator changed following an accident. The coolant is like new and the level has not changed since I brought the car home. The timing chain, observable from the oil filler cap, looks new and is nicely taught. The engine is noisier than my 4.2L Vanden Plas which I de-winterised today---started first pull as usual! It's the fuel pump(s) and injectors making the noise.
My major thing now is to get new rubber----three of my tires are original (Nov 2011) .I am thinking Conti Extremecontact DWS 06 Plus
Well my 2012 XF Portfolio is now legally on the road. I still need to get tires but everything else is checked OK. I installed my monitoring system for engine coolant temperature and oil temperature. I think I should be able to diagnose cooling issues as they happen.
Another member put me on to this device--Autool X60 for $32 Can including taxes and delivery. Plugs into the OBD port and shuts off automatically. As you can see oil and water temps on same screen along with alternator output/battery voltage.
Is it a bit overkill the position you place it at because now u cannot see the digital speedometer and the fuel remaining.
I didn’t hear about people having oil temperature or coolant temperature issues but I have heard of coolant leak issues which gets indicated with ‘Low Coolant’ warning then you must try to pull over immediately to check before blowing up the engine lol.
I wish it was a small screen but for the price u can’t go wrong.
Yes, I understand your reluctance. My thinking was --it is inexpensive, easy to install ,no dangling wire( easily threaded inside steering column covers) and can easily be removed including the gel adhesive. Anyway I will try for a while and see how I like it.
Got my Conti Extreme Contact DWS-06 Plus tires installed today. For the first time in my experience they were less expensive than the Tire Rack price by about $9 US per tire. They are light, 24lbs each and on the tire balancer had the lowest and most consistent road force variation the installer has seen. I took a short ride after and am very happy with the noise and ride. Tires were made in Portugal.
My 2012 XF Portfolio is not a daily driver. So far I have done about 3000kms since April, with a total of 47,500kms, and all has been well until last Friday when the first check engine warning appeared. Checked the code ---P0106 MAP Sensor-- checked the live data and sensor output at least appeared to be moving in the right directions. I decided to clean the throttle body and butterfly plate and the MAP. I did the throttle body in place after removing the air intake tubes. The MAP sensor I removed to clean. All appears OK so far.
Monday I was out visiting our former neighbors and on the return trip I got the " TPMS system fault" warning without any low tire pressure notification. Checked all the tire sensors with sensor checker--all were showing good batteries,38psi pressure and 87F temperature. I was unable to see any DTCs on my JLR SDD system. I decided to check all the "Initiators" or antennae and found the front drivers side antenna had jumped out of its vertical holder and was lying flat on the front plastic shield. After repositioning and securing it with tie wraps my TPMS is working normally.
Reason: spelling
Just something I found out on my 2014 XJR when I recently replaced all 4 tires. TPMS have a lifespan of around 5-10 years before they die and need replacement. This is because the batteries are NOT replaceable and eventually fail. TPMS Replacement
I did not know this and thought the batteries could be replaced. Now they can IF you have an external type of TPMS but all factory systems are internal with the sealed battery set up. So with the age of your car if you have not replaced all of the TPMS stuff it's getting close to the time when they will fail. Just something to consider as you can get the TPMS stuff cheap from China (I got all 4 for around $40 including shipping off EBay) Jaguar wants about $130 EACH!!! Heck even Discount Tire who recommended me changing them wanted over $100 a piece too!
Make sure you get the correct ones as there are 2 different frequencies used around the world. In the US it is mainly 433MHZ but Jaguar sells cars all over the world and uses both 433 and 315 frequencies. The sensors are marked with the frequency so at worst case just dismount a tire and have a look.
Yes I was aware of that. Also the mileage covered by the vehicle is an equally significant factor. Because of the low mileage on the car and the fact that I have free and easy access to a sensor checking tool I decided to stick with the existing sensors. The sensor checker also identifies sensor frequency, battery condition and programs the sensors. On my 2012XF the sensors are 315MHz. I have been looking for a replacement source but am concerned about whether or not some cheap sensors will work properly. If you could PM me the source you used on e-bay I would appreciate it.--
I drove up to Ottawa today and completed the 400kms journey in 3hr 30mins---this car is so easy to drive---maybe I need an XFR!!
hi , iam new member, resently became an owner of 2012 portfolio, it’s my first night reading different post, I see you have a lot done , and had a great knowledge about the car , question should there be 2 Tpms antennas? I only had 1 , and common problem with Tire Pressure System Fault !
do you know how those antennas working and should they be installed in some spec place?
There are four TPMS antennae (or initiators) one for each wheel. The fronts are located on the lower plastic shields in front of the wheels, and the rears are behind the wheels underneath the mud covers. I am unaware of any test for their functionality---maybe someone else can chip in.
Just fitted a new set of brakes to my 2012 XF. Decided to go with a set of Power Stop K6283 brakes with Z23Evolution pads. I followed their procedure for bedding in and I think they are going to be very good. The brakes are much easier to modulate at lower speeds. I have not had a chance to do any higher speed stops yet. Front after bedding in and 60 miles Rear
