2012 XF Portfolio Stall HELP!
Hi all,
I've been doing some research and it seems like there are a few of these cars that have the same issue. Does anyone know how to resolve it?
I've seen several different recommendations on how to fix it but nothing concrete.
I replaced the air filters and performed a fuel injection flush and it helped for about 2 weeks. Then the car started stalling regularly and now wont turn back on. My local mechanic has stated the following as of today:
1. Its registering 7 volts and should be 12 volts
2. Pressure sensor wants 1300 getting 1800
3. Sensor on fuel pressure regulator is off.
Thank you
Thank you
