2012 XF Portfolio V8 Gas Gauge.
This is a known issue with the connectors on the fuel level sensor on the pump module that sits inside the tank. I've attached the TSB that describes the issue and how to fix it, along with the workshop manual section to remove it.
I'd recommend a fuel ring removal tool as mine needed not only this but a breaker bar with a cheater bar on top, but apparently others have had success removing theirs with a screwdriver and a hammer.
Definitely the same issue as in that TSB I posted above - those were the symptoms I experienced.
Richard Zuniga (07-10-2020)
