2012 xf sc 5.0 camshaft position sensors
Can someone tell me if the camshaft position sensors bank 1 bank 2 sensor A sensor B are all the same? I have p0016 and p0366 now where I originally only had only a p0016 bank 1 sensor A. I made an error installing the new sensor in bank 2 sensor A. Left the new one in bank 2 sensor A and swapped it to bank 1 sensor A. If they are all the same I was thinking of changing bank 1 A and B with new ones as the p0366 shows bank 1 sensor B now. I should have done more research before tackling this 🙄
Even with both bank 1 sensor "a" and "b" codes, the motor does run. I've only started the vehicle with this showing up on dashboard, never driven with the message showing up. Just really really hoping this didn't jump time and I failed to mention from the start that the vehicle does run. Ordered two new sensors and going to install next week. Still wondering if there is a relearn procedure that should be followed after installing new sensors?
Follow what Xalty said above? Forget the relearn thing. Xalty repairs Jaguar's for a living and any advice you get from him is based on the vast amount of Jaguar experience he has.
Have you checked the tensioners?
Have they been replaced prior to this?
What lead to you replacing the camshaft sensors?
afs914
09-08-2023 09:12 AM
