2013 Jaguar XF awd s/c
Afaik there isn't much. Mina exhausts are well known. I'm looking for a good intake to open up the SC whine a bit, but haven't found anything.
There is also a larger bottom pulley and ECU tune from VelocityAP you can buy that swaps in and adds about 40 hp I believe for the pulley, and i think 100hp total with the ECU tune?
Go for the tune
The tune alone will give you 410-420 hp crank
Viuze ,velocity, RSC tuning or Eurocars have great tunes. Plus its very simple and easy to get done. Lower Pulley (Only) is a fantastic addition but more work ...puts you up to 450 + however you must add meth and a better rad . I had killer chiller installed along with exhaust which completely changes the performance... Its much faster than a 4.2 sc v8 xfr
i just wish xf could have access ( similar mufflers) to equal the exhaust note of the Ftype...
ps) you cant do upper and lower on a 3.0... the upper alone is a waste of money as its garners you minimal gains. Lower is amazing for V8 like torque.. remember to up the cooling.
Received 3,209 Likes
There appears to be a fair bit of confusion here about lower pulley vs tune.
A larger crank/lower pulley by itself will NOT give you more power and torque, in fact quite the opposite, it will cause the car to go into limp mode ("restricted performance") as soon as you give it the beans over around 4,500 rpm.
If you fit a larger crank pulley then you MUST get the associated tune to prevent this happening and to reap the benefit of the pulley.
The pulley and tune combo, at least the VAP version, will take it to a safe 450 hp with zero other modifications.
Or you can go with a "tune only" for 410 - 412 hp.
well i have tested 5 diferent 3.0SC engines both AWD and RWD in XF x250, and x260 also in F-type by no means any of those come close to 4.2sc engine anywhere up to 4000RPM, where 3.0sc with more advanced TVS charger starts opening up, and old generation m112 starts fade away at 5500rpm. a 4.2sc with LSD is agin diferent story.
User 42324 (06-27-2020)
Were are bot talking stick 3.0 here
both re-program Ecu, 300 cel cats, pulleys, larger intercooler Meth injection, cat back exhaust, h pipe
.... love the durability of the 4.2 however its limited by the heat sink Eaton blower
Mina i take tubes...
CleanJag
06-14-2020 05:30 AM
