2013 XF 3.0 AWD SC loud knocking sound
Greetings.
Drove on the highway today. After around 170 km engine started making knocking sound so loud I heard it through AC and music.
At idle it sounds like a noise it had for past 1.5 years but MUCH louder. I was told that it was a supercharger coupler and nothing will happen - it will just make this sound and that's it.
When RPM goes up it starts to sound like an old tractor.
Vibrations felt when at idle.
When engine starts it feels like it struggles to pull something. After it starts it feels normal (aside from vibrations). Idle RPM is 800. Bluedriver shows no trouble codes.
With engine cover on it seems that sound comes from lower right if you're facing the bonnet. With cover off it seems like sound comes right from the middle of the supercharger.
Will upload videos shortly.
What could it be?
What could it be?
Greetings.
What could it be?
What could it be?
Greetings.
What could it be?
What could it be?
Here are them videos:
In MOV 0102 at 0:20 you can see me zooming on the pipe and touching it. You can't see it on camera, but it vibrates. Pulley that is to the left of it vibrates as well.
For real everything sounds just like in these videos only much louder.
Took supercharger belt off. With supercharger it soudns like death. Without supercharger it sounds a lot less scary, but still like knocking.
My worst suspicion is something broke off inside the supercharger and some small part(s) of it got into cylinders. Is it possible? If so, how likely it is?
Received 3,225 Likes
That is not the classic worn SC coupler / torsion isolator noise at all, it sounds much more serious than that to me.
A worn coupler makes an irregular medium/high pitched rattle like "marbles in a tin can" then a loud "clonk" on shut down, while your sound is much deeper and quite regular.
Don't start the engine again let alone drive it you will just make things much worse.
VPinGA (06-13-2021)
That would be the second thing I'll do. First would be to look inside each cylinder to see is there are any metal pieces that got broken off supercharger.
2010 XF Supercharged
Fully Rebuilt Engine - Upper Pulley - Custom Mahle Forged Pistons - Uprated Intercooler - Custom Cold Air Intake - X Pipe - Mina Mufflers
Custom Vacuum/Boost & Oil Pressure/Temp Gauges In Dash - Full Suede/Carbon Retrim - Custom Vented Hood
Work In Progress
Supercharger Intercooler Ice Tank - Supercharger Porting - Full Trans Rebuild With Exedy Stage 3 Clutch Pack - Heated/Cooled Rear Seats - Rear Diff/Motor Cooling - Project 8 Fenders.
Work In Progress
Sounds like a piston hitting a valve to me, do a compression or leakdown test.
Hard to tell but i suggest you look on ebay or AliExpress, they sell they whole kit. Then quote labor at some garage.
Here is a post about this issue with a lot of videos and details, sounds exactly like the problem they describe.
https://www.jaguarforums.com/forum/x...-noise-173371/
Greetings.
What could it be?
What could it be?
Spoiler
