2013 XF 3.0 Coolant Story ( Believe it or not )
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Just curious about what everyone out there thinks about events that just occurred with my 2013 Jaguar XF 6 Cylinder with 51k miles. I will start by saying there were no coolant (WET) spots on my garage floor.
1st. Warning Light came on low coolant so I put in 1 gallon , forgot if it was Red or Pink but it was the required coolant for a Jag , the next morning drove 5 miles round trip to get my WaWa coffee , pop the hood and all the coolant was very low.
2nd. Take it to the repair garage up the street and explain all events so far. They called back and said the water pump was leaking when the car was running ( made it sound like they knew what they were talking about ). So they installed new water pump …....
3rd. Repair shop called and said car is fixed , I went to pick it & up pay the shop $900. Start the car and warning light comes on AS soon as I start the car but the coolant tank is full of anti freeze , didn't even drive the car off his lot ….. Leave the car and go home …..
4th. Next day shop calls to say the float in the tank isn't working and the Coolant reservoir has to be replaced and this is the reason the dashboard light is saying need coolant , sooo they replace the tank
5th. Next Day the shop calls again and says NOW the car is actually leaking coolant from the O ring on my turbo charger (NO IDEA OF WHAT THIS IS)
Few days later I get the car back and all seems to be fine, I'm asking all in the community are all of these events possible, did the repair shop fix one thing then break another , do I have this bad of luck or is Jaguar just a car that's fun to drive but breaks often and you need spare car?
This is the average repair experience on Jags, even with those low miles. You need either a trusted shop experienced with the brand that doesn't use the cars complexity as a license to rob you blind, or be like people on this forum pouring over codes, diagrams and schematics to make sense of what it will take to fix these things.
Jeff Murray (09-30-2021)
Water pump leaking and the float in the expansion tank failing are pretty common issues. So quite possible that both were true. Plastics and hoses go brittle over time so they may have caused a different leak while doing the work
But - $900 for water pump is a lot. Indy should be a lot cheaper
Last thought - if you need to put in a gallon of coolant you have a very serious leak. I wouldn't drive it like that...
Yes, the float in the expansion tank is a PITA, I've had this on a brand new expansion tank like 5k miles after I replaced it. Just needed reseating but they definitely stick/fail on older tanks. Water pumps leaking is probably the most common issue on the 3.0 and 5.0 engines, and is basically down to the flawed design of how the water pump mounts to the block. That's never going to get changed/fixed, so Jaguar has gone through various iterations of pump to try and solve the issue, to apparently varying degrees of success.
And yes, $900 leaves quite the labor charge given that the pump new from jag dealer is ~$300. Find a good indy or failing that, a good tool kit and a copy of the workshop manual!
davetibbs (10-03-2021)
pdupler that tube is available in Aluminum from the aftermarket in case you have not seen it?
Engine Oil Cooler Tube
Pretty cheap at $12 too.
I'm not quite so sure that its a problem with the pump and the mounting to the block is very much like many other cars. There are two squirrelly round seals in a short segment of tube between the oil cooler and the back of pump that are a really a poor design and can basically roll over on themselves if enough pressure builds or if they were not carefully installed in the first place. That seems fairly common too, but technically not a failure of the pump. The pump commonly fails at the shaft seal. I'm trying a < $100 aftermarket pump for #4 so if it lasts another year then I may go back to thinking it was Jaguar's pumps. However, I'm kind of thinking it has to be something else in the system because at least anecdotally the XF's seem to be affected to a much greater degree than the XJs, XKs and F-types. But like the Jaguar engineers, I'm just guessing.
Hi, this seems like a good place to ask about coolant.
I have a 2015 XF 3.0. Is this the right coolant?
Current Hers: '13 Lexus ES350
Current Mine: '15 Jaguar XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
Carla Barber
07-13-2020 07:46 AM
blaydes99
07-07-2014 10:41 AM
