2013 XF Engine Defrost Plug?
Has anyone ever heard of a "frost plug" on an XF engine? Something that, if loose, would cause engine oil to leak out? Like, all of it? If you know, where is it and what is it for?
I think you mean freeze plug. It is for the coolant.
A true freeze plug is an expansion plug located in the side of an engine block that is supposed to protect the block against freeze damage. Water expands when it turns to ice, and if the coolant does not have enough protection it can freeze and crack the engine block. The freeze plugs (there are usually several) are supposed to pop out under such conditions to relieve the pressure on the block.
Kristin_w (10-07-2013)
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
