2013 XF Parking Aid issues repaired not working
Hi All, I have seen several write ups regarding this topic and even found my exact problem from @Real_Tech here:
https://www.jaguarforums.com/forum/g...83/#post171539
Found the a wire corroded and Did the same, replaced the wire loom and the beep from the parking aid stopped for a bit but camera not function contact dealer message came on all the time. Now the beep is back too
Is there a way to do the "hard reset " he mentions here without the diagnostic tool? Could that be the issue? Was hoping to text and get the bumper back on soon but don;t have the Diagnostic available
"I return 5 seconds later with a stethoscope. I tell normal tech turn the ignition on and put it in gear while I listen to the sensors. I hear nothing front or rear. I ask the tech if the module is plugged in and he assures me yes. I say lets do a hard reset, maybe the module is locking out operation due to the fault. He turns key back on and puts in gear and I get about a millisecond of noise from rear sensor. I say hard reset again and listen to the front where I get no noise at all. Now it's coming to me and I ask the tech "during the SDD diagnostic procedure it never did ask us to check voltage or ground at an individual sensor did it?" he says "um, no". I say "pull the F'in front bumper off" where to the SDDs surprise is a pinched signal return wire covered in green corossion. Ordered front bumper harness for replacement the next day, XF fixed".
Christina Emily Manning
04-23-2019 02:38 PM
mjbedingfield
08-28-2008 09:42 AM
mjbedingfield
08-04-2008 06:09 PM
