2013 xf sputters until I rev really high (after fueling)
Old 01-08-2019, 08:09 AM
pireality's Avatar
Default 2013 xf sputters until I rev really high (after fueling)
I have taken the cap off for a similar amount of time to fueling and put it back and and it starts right up, it happens if I top it of, fill it until the pump stops automatically, or if I don't fill it all the way. It appears to be directly related to putting fuel in. I will run a gallon of denatured alcohol through it to see if there is water in the tank, but could it be something else?
Old 01-08-2019, 11:23 PM
lotusespritse's Avatar
Keep in mind that water is heavier than gasoline so it sinks to the bottom of the tank. If you have water in your tank and run your engine, that water won't stay in your gas tank for very long because it will be the first fluid to get sucked up by the fuel pump.
If you suspect the gas station you are going to is pumping water into your tank, I would go to another gas station as a test. This is extremely rare these days, and if it wasn't rare, everyone filling up at that station would have trouble driving off after filling up. That would make the local news pretty quickly.
In other words, I give it about a .000001% chance that water in your gas tank is the problem.
Old 01-09-2019, 12:47 AM
Received 4,464 Likes on 2,427 Posts
Faulty purge valve, stuck open probably, as you fill the tank the fumes which are displaced by the incoming fuel are pushed through the open valve into the intake manifold, so it kind of floods the engine.
03s-type_sport
05-28-2017 06:26 PM
Kewpie
11-18-2016 09:59 AM
82WingNut
10-21-2016 05:57 PM
chazaroo
12-30-2009 07:39 PM
XJ ate
02-23-2009 06:31 PM
Quick Reply: 2013 xf sputters until I rev really high (after fueling)
