2015 Jaguar XF 3.0L Portfolio - Coolant Problems
I have had so many coolant problems since I bought this car new in 2015. Is anyone else having problems? I have 69,000 miles, take excellent care of car and do all service maintenance. In 2018 they had to replace the coolant outlet pipe (still under warranty). 2019 had to replace coolant outlet pipe and water pump again (under warranty). 2020 had to replace coolant rear crossover pipe $919.00. 2020 had to replace thermostat housing. 2022 had to replace coolant level sensor with expansion tank $535.00. NOW I have to replace the Coolant Outlet Y Pipe because there is a huge leak and they want $2,800!
This can NOT be normal wear and tear because I take excellent care of my car. Can some PLEASE help me! I believe I have a faulty car a real lemon.
If it's any consolation, I have changed most of the hoses or fittings you have mentioned on my 2014 3.0 since owning it for 5 years. These parts being made from plastic will inevitable fail, so you are faced with having to replace them. thankfully some of the parts in the cooling system are being manufactured in metal...
are you taking your car to the dealer or a specialist? the Y pipe is under the SC so that needs to come off its a big job.... make sure u get a metal version to replace the plastic version.
https://euro-amp.com/products/jaguar...charged-engine
amwalters (04-12-2023)
I wish I could find a good mechanic that worked on Jags near me, but can not find one. I will probably also be getting rid of my 2015 Jaguar XF 3.0L Portfolio and moving on to a more dependable car. I hate it because I really have enjoyed the beautiful car but at this point I am ready to let her go and I am DONE with Jaguar vehicles from now on!!!!
I recently picked up a 2014 xfr. I currently am having to replace the thermostat housing. Going to replace all the connections with t-bolt clamps. Purchase the metal parts that I can without having to take off the Super charger yet.
The one suggestion that I would make is that I'm going to switch to Evan's coolant. With it's much higher threshold for a boiling point. It will reduce the pressure on the coolant pipes and lines.
That is my suggestion. Something to look into.
