2015 XF Splitter install and grille swap (before/after)
I apologize for posting the photos out of order. This was done from my mobile device and I had to download the photos in segments. Needless to say, they posted backwards. Nevertheless,....enjoy.
Money shot
New blacked-out grille
Front splitter and new grille
New side splitter from Maxton Designs
Rear and side splitter view
Side view
Before splitter install
Money shot
Side view
Panthro (09-02-2019)
Very clean install, I like the Draco wheels in the silver, too....
What is behind the side grilles on the R? I note that the mesh is open, while on my XF Sport they are closed mesh, it bugs me.Are there air ducts to the brakes or just open space in there?
I would wipe that splitter off in half an hour...Even with the parking sensors it would make me nervous.Trashed the one on my Mini 3 times!Oh, well.
The mesh is closed above the chrome piece (which is blacked-out on mine). The mesh is open below it. There are sensors that look like paddles that sit behind it. From what I've read, they are ambient temperature sensors so they actually serve a purpose believe it or not.
Is the car an actual XFR? If it is their should be an auxiliary cooling radiator behind each intake. I think the earlier XFR and Supercharged models had one radiator but the later models (at least on my 2012) have one on each side. Was this bumper/fender ever intended to be fitted to the XFR model? If so, the smaller intakes might be limiting the air to the auxiliary radiators.
Just saw your signature on your second post so the car is an XFR.
Paul Fisher (02-19-2019)
The front intercooler radiator is not particularly beefy, and I've replaced mine with a larger one from Allisport. All the jags with the 5.0 V8 SC engine (XF,XJ,XK,F-Type) share the same intercooler radiator with the same part number, so any radiator upgrade for an F-Type will also fit a Jaguar XF.
The following 2 users liked this post by davetibbs:
MarkN (02-21-2019),
Boy Dave I wish I had seen this earlier!
Just paid a LOT more for the inter-cooler from Paramount Performance!
So thanks for the link even if it's too late.
But I have been researching this on my 2014 XJR. It has a passenger side AUX radiator. But looking in the shop manual it appears Jaguar installed these on the left and right sides depending on what market the car was sold in.
Maybe some hot places like the middle east might have gotten AUX radiators on both sides?
I was considering trying to add the AUX radiator to my drivers side but have never seen anyone talking about this?
It also appears the radiators and ducts are the same between the XF and XJ but again not sure?
Hope you can comment on this?
The only other thing I'd say is that there's nothing really that special about these radiators. Sure, they're sized to fit the vent, and they have angled inlet/outlet pipes etc, but you could absolutely fit a (thicker) universal one with minimal fabrication work I reckon.
Received 3,263 Likes
On at least the earlier "pre-facelift" XFR, so from 2009 to early 2012, there were two set-ups for the auxiliary radiator(s). This may or may not have been the same on the later "facelift" XFR from 2012 to 2105, I don't know.
The "normal" set-up was with only one of them, behind the lower RHS grille vent, with a plastic blanking panel behind the LHS vent (I still have that piece of plastic), and the "hot climate" set-up was with two auxiliary radiators, one behind each vent.
My Oz spec 2010 XFR had only the single auxiliary radiator even though it sometimes gets to 110 F where I live, I have no idea why my part of Oz was not considered "hot climate", and to the best of my knowledge "hot climate" was restricted to the Middle East (Saudi Arabia etc).
My copy of the 2010-2011 XFR Workshop Manual shows both set-ups.
Huh, interesting. I've just checked and my 2010 Jaguar XF 5.0 Supercharged has both auxiliary radiators fitted. Not sure why - it spent the first 5 years of it's life in Houston TX where it doesn't really get higher than the high 90s, so I'm surprised they thought it was required. On the other hand, that engine bay gets hot so I'm not sad I have it.
If I had the blanking plate I'd consider using the space for additional supercharger intercooling over engine cooling, but I guess it depends on priorities
Looks freaking awesome.
I'm looking into getting a front splitter only and my bumper is the same as yours.
Could you confirm that this is the one you bought?
https://maxtondesign.com/product-eng...-FACELIFT.html
The maxton site doesn't show a photo of the splitter installed on this model, it just shows the sportbreak without it. I assume the front of the sedan is the same as the sportbreak.
cpcooper
03-08-2014 12:45 PM
SpartanX
08-24-2012 10:47 AM
