2015 XF Wheel bearing
I have a 2015 XF with a failed front wheel bearing. I've been waiting since July of 2021 for a replacement wheel bearing. My car has been undriveable for two months. I was told, by the local Jaguar dealer, that the part would be in early November, but now that it's early November, they don't have anything and they are no longer giving me a date. Has anyone else experienced problems with replacement parts from Jaguar? Are there any other options?
Note that you can't just buy a bearing. It comes as part of an assembly.
Yes - all manufacturers are having similar challenges with supply availability and logistics if it's overseas. I had to wait several months for rotors (fortunately not urgent for me)
You can get aftermarket ones that seem to work well. Search on here - others have gone that route. Cheaper too
I wouldn't wait for OEM if you can't drive the car...
I can't believe you've had the car off the road since July when parts like this are all over the internet ! Obviously it's not your daily driver.
Edit
Apologies. It seems the AWD front hub is much less common. SNG Barratt have it as part of the suspension upright at an eye-watering £580 !!! I suspect, if one can get the bearings, that it should be possible to replace them, but can one get the grease seals as well ?
Edit
Edit
Edit
Yes, the price you mention is in line with the quotes I've been given for the part. You get a whole bunch of suspension parts for free with every wheel bearing. I suspect that the problem is the dealer will only use "genuine Jaguar" parts.
BTW the XF is really good in snow with AWD (especially if you remember to press the "snow" button). It will easily go through snow drifts that completely stop my wife's 4WD Ford Escape.
Well, let me say how relieved I am that you are "in warranty". This will take a lot of weight off your shoulders, I'm sure. Of course it doesn't actually get the car fixed ! If the car is being dealt with by the Jaguar main agent, then, yes, the dealer will use "genuine Jaguar" parts. What is not clear is whether the suspension upright is peculiar to the AWD car or not. The hubs are obviously different because they have to take a drive shaft. The non-AWD hubs are secured at the rear of the upright by four bolts, and are also notorious for corrosion making them very difficult to remove from the alloy upright.
A quick sprint round the internet came up with this: -
https://www.ebay.co.uk/itm/224482855...RoC9HcQAvD_BwE
Obviously about half the price of the SNG Barratt offer, but that includes the upright, whereas here its just the hub, and it looks like it is secured the same way as the non-AWD hubs. Clearly it would be stupid of Jaguar to have to produce totally separate uprights for AWD cars, and I suspect they haven't. It looks like just the hub is redesigned to take a driveshaft.
