255/45 r19 instead 245/45 r19
I am going to change my tires 245/45 r19 in the next 6 months. I was thinking about putting different size 255/45 r19 on the original wheels r19. What are your thoughts guys? Will I have problems to install them? Will I have problems with my jag, the way it drives? Or should I stick to original tire size?
You shouldn't have any problems with fit. There's plenty of clearance for a slightly wider and taller tire. Others will probably chime in here that going with a taller tire is going to wreak havoc on you ABS, traction control, etc., but it won't. The 255/40 just a little over 1% taller which is well within the range considered safe in the wheel and tire industry.
Now, your speedo will be slightly off. You'll be travelling a lil faster than the speedo reads.
Excellent all weather tire. I have the full winter version on my SAAB Aero and they are superb.
Oops, continental nomenclature caught me out again. DW does mean Dry Wet. All weather version is the DWS. With the S for Snow of course.
The really high performance Contis are the contact 2, 3 and newest 5P
These also get high ratings in the press and from users.
DpezXK8
01-13-2015 05:44 PM
