4.2 XF will crank but not start when hot
Old 04-28-2024, 11:10 AM
RMDman's Avatar
Default 4.2 XF will crank but not start when hot
As the title states, when the engine (4.2) is fully warmed after a drive and I make a short stop, for an errand in a store or such. The engine will crank , but not start. In all occasions if I wait for about 10-15 minutes the car starts and runs fine. This does not happen all the time. I may go a week or more and then suddenly there is that time where it will not start and I have to just sit and wait.
I have replaced the thermostat. It was broken. It didn't correct the problem. It posts no codes. thought I was replacing the fuel filter , but the part ended up being the fuel flange. I replaced it anyway, no difference.
Has anyone had this problem and actually found an answer.
Additionally where is the fuel filter located in a 2010 XF. Is it part of the fuel pump assembly? Or is it located somewhere else?
Old 04-28-2024, 11:15 AM
xalty's Avatar
Received 1,067 Likes on 857 Posts
in left wheel well
Old 05-01-2024, 04:23 PM
JagV8's Avatar
Received 4,564 Likes on 3,968 Posts
Maybe a sensor is off & fooling the air/fuel calculation. Have a look with OBD live data to see if any is obviously wrong (but probably near enough to fool the PCM into not flagging codes).
foleyaxle
10-22-2022 04:35 PM
tyler12345
06-03-2022 08:51 PM
Geoff_C
10-05-2020 02:21 AM
Nik Burkhardt
10-23-2019 10:41 AM
Quick Reply: 4.2 XF will crank but not start when hot
