5.0 Broken Timing Guide
I read that about the socket in another thread, somebody made the recommendation to still buy the factory socket if buying a cheap tool kit.
That sounds like a good recommendation for the socket, or at least get a good quality impact socket. The only thing is, if you're using the crank pulley tool which goes against a jack stand - and honestly, I recommend that you do use one of these, chinese copy or not, it can be tricky to find a socket deep enough to clear the tool, and it's hard (but not impossible) to do with (eg) a smaller socket and an extension bar. I'll see if I can find a link to the one I bought.
These bolts are on tight (which is why the information about identifying which way the bolt is threaded is so crucial, there's been tales of snapped bolts on here which = replacement crank). Prepare for cheater bars or at least a high torque impact gun once you know which way to extract the bolt.
Received 3,259 Likes
2010/11 XFR Workshop Manual here: https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
AJ133 Training PDF here: https://www.dropbox.com/s/8y4iax9hm2...%20V8.pdf?dl=0
davetibbs (06-27-2021)
