5.0L engine noise
Cherry_560sel (01-22-2016)
I'm mostly worried about the paddles for the TPMS modules that are attached to the tray under the bumper. I just got the TPMS module reflashed and I don't want to drive the dam 3.0T loaner again...lol...not that it's a bad car, but it compares more to my Xtype than it does to this 5.0L
Look back about a year ago. A great article about how to install a grill badge using a small piece of plexiglass and a toggle anchor (like for drywall) and putting in a mount without having to remove the bumper. I did it maybe 18months ago - took half an hour in total. And no issues since
RonAsonte12 (05-02-2017)
Received 3,216 Likes
I did this using a piece of 1 mm thick aluminium cut to shape as a mounting plate, but it was tough to chamfer the edge of the hole "just right". Take too much off and the screw/bolt pulls through, not enough and the screw sticks out too far.
Next time around I used black silicon RTV windscreen sealant - fill the appropriate hole in the grille with some, slightly overfill it, press and hold the badge in place for about one minute, dead easy, worked a charm, the badge hasn't budged in 8 months, and sits flat on the grille with no pesky bracket in the way.
Muffler delete and resonator delete went well. Any XF NA owners out there listen carefully. DO THIS NOW. My gas mileage went up by 25%....the sound is pleasantly noticeable in daily commute driving. Not harsh at all...now, if you open her up, it will be loud....but I like that ...thanks to everyone who helped out on this. Awesome advise from senior members! The grill badge is super easy to do. Use the toggle bolt method. It took a little modification, but didn't have to jack with taking the bumper off.
To the OP regarding the Engine noise.
My engine 2012 5.0 at 75000km also sounded like a diesel.
Please see my thread :
https://www.jaguarforums.com/forum/x...-wrong-145779/
The Jaguar techs didnt find the cause of the noise but they "tested the engine and found low oil pressure" in which JLR approved me of an engine replacement. Noise was gone with the new engine.
Please be advised I know of another person with the same engine ... 2012 XF 5.0L and same noise as mine. He got his belt tensioner replaced which seems to have solved the issue.
My new engine is starting to develop the noise again as I hear it on warm startup idle sometimes. I think its a bad design issue.
#30
Lol...so you have the same noise again...only from a new engine...nice. At least it's not bothersome anymore, but I will need to really get used to driving a car that sounds like this. I mean, inside...no noise..outside...sounds like crap. cant even hear the exhaust note clearly because there is such a shitty noise from the engine. other than that, the car runs and drives fine with no issues.
#31
I just can't think of any mechanical component that would only be intermittently faulty or only sometimes not work as designed. So I'm lost.
#32
#33
Received 2,192 Likes
sorry to revive this old thread...but, my 2011 xf also had me worried. I also would describe it as a "diesel" engine noise. But inside you can't hear it. I was worried about it and the service manager also said it was a normal thing for the 5.0 liter engines. I hope with the exhaust upgrade i am planning i will be able to negate that noise with a pleasant, throaty rumble. Although, to be honest, i haven't seen many youtube post of the xf 5.0l na with exhaust mods. I just find a lot of xfr or xf sc videos. Anyhoo, having read this thread put my mind more at ease, even though i won't be happy until that sound is drowned out.
#34
Brutal, here is a video of the "throb" or "knock" that I get sometimes, as heard from the interior. Any idea what it might be or why it would only occur sometimes?
#36
It could be your supercharger coupler, sure. And this is easy to test - it's safe to run the engine without the supercharger belt, as the bypass valve will bleed enough air through to run the engine and rev it a bit (not under load). So the first step should be to remove the supercharger belt. This will allow you to run the engine and see if the noise is gone, and also give the supercharger pulley a turn by hand to see if you can feel/hear any issues.
I have to say the more of these threads I read on this subject about the 5.0 v8 engine which range from an unsatisfactory noise which results in timing gear replacement all the way to outright engine failure like mine, especially in the Range Rover world, makes me think this problem is wider spread than maybe we're prepared to admit. When I bought my car I had the impression the engine was seen as very strong with no real obvious issues, and now I'm wondering if it's not just that people were focusing almost entirely on the fact that the rear diff issues of the 4.2 V8 had been resolved.
MarkN (05-09-2017)
#37
Dave, Shadow, thanks for your replies. I just published this post in the XJ forum that my help you understand the whole picture of what I've been hearing and feeling.
https://www.jaguarforums.com/forum/x...riance-181551/
I had the coupler inspected and they said it was fine - so as stated in the post, I'm lost!
innzane
09-02-2015 10:08 AM
