Is 600 CCA battery enough for 4 cyl.?
I will go to junk yard tomorrow to get a battery. I'll try to get more CCA, but it is 4 cyl engine and turbo engines have low compression. Shouldn't 600 CCA be enough for Florida?
$30+$15 core for a battery, they get more expensive every year.
https://acepickapart.com/pricing.php?a=b
I have to agree. As touchy as these cars are to batteries that are even slightly less than perfect I think it's crazy to shop for one at a junkyard. Try Costco or Walmart for a good price.
Jag#4 (04-25-2020)
Such tester was used in front of me before selling me the batter.
https://www.harborfreight.com/100a-6...gaAtgMEALw_wcB
And it was tested while in your car, correct? To test the proper load ( as put on the battery by starting and running a jaguar, you need to use a tester in the car while charging it .
A "good battery" can take a load and will charge the battery quickly under load after starting. You can alternatively use a charger that has the same output as the alternator but its best to see if your alternator can charge the battery.
Here is a decent Youtube video that show you how to do it correctly (with a similar tool and a charger) If the shop did all this you should be good.
