ABS Sensor Pocket Replacement
Hi,
Just had the common "ABS and DSC fault" on my 2010 Jag XF Premium Lux 3.0L Auto. Did some research on here (many thanks) and after nothing untoward seen when inspecting ABS sensors or reluctor rings, I decided to have the code read. Front drivers side ABS sensor was the culprit!
After a call to the local Jag dealer and being quoted £130 for a new sensor, I decided to purchase a second hand tested sensor off Ebay, which i duly fitted.
Codes now cleared and all fault indications cleared - happy dayz!
Problem: When removing the clip to remove the defective sensor, part of the plastic (?) moulding on the back of the hub cap that the ABS sensor locates into snapped off. This now means that the sensor cannot be held securely in place using the sprung retaining clip. Whilst I could just try and "bodge" something to hold it in place, is it possible to replace what appears to be the plastic cap on the rear of the hub (which contains the ABS sensor pocket) without having to replace the whole hub? If so, what is the actual part called? Does anyone have a part number please? Anyone know where I can get one?
Many thanks for your assistance.
