AC issue
I’d be interested to hear if anyone has had their pressure sensing valve replaced?
https://www.google.com/amp/s/www.car...1420681139395/
On both my Jags, only on occasion, the A/C will blow warm for the first 2 or so miles, and then blow nice and cold for the rest of the trip. And it's pretty rare to do that on my white one. Maybe a couple times since we got it in 2011. On the grey XF, it's done is a few times in the past couple of months of daily driving. All other times the AC blows cold from the get go, and always does a good job.
It seems like that could be an intermittent sensor issue.
Interesting.
I experienced a on and off issue with my 2010 XF A/C and I took it to Jaguar and they fixed it. What they said was that the A/C was over charged. They drained the system then recharged the system using the weight of the coolant and not the pressure readings we are so familiar with.
Gus
JagRepair.com - Jaguar Repair Information Resource
Gus
Gus
Gus
If you find yourself standing in front of those cans wanting to buy one, you know you're about to make things worse. Most of them contain stop leak, which never stops a leak, but has been known to f-up the entire system.
Life has definitely changed. Modern car AC systems have a very small margin for error on amount of refrigerant, either too much or too little, but most people don't know that because the cars from the 70's and 80's weren't so sensitive and they think they are the same now.
Gus (05-19-2019)
Interesting.
The local shop I took it to claimed they could handle checking the AC system on a Jaguar. It turns out they were clueless on JLR vehicles and identified nothing. The vehicle is going to the local Jaguar dealership this Friday. I will post results as soon as I find out. Be aware there is a TSB that covers 2010 to 2016 for the Direct Pressure Sensing Valve as it must be prone to failure. TSB JTB00380NAS4
deanmartini (06-06-2019)
https://www.coolairparts.com/index.p...roduct_id=4155
I just did a compressor change on my Lamborghini, so any other car will seem easy compared to that one!
That seems like you have a different problem. On mine, it will blow warm as if the compressor is not running at all for the first couple of miles, despite how fast I am going. So it's not fan dependent. And then it will blow great the rest of the trip even if I am in stop and go traffic where the fan has to do all the work for the A/C to function. If I had a fan problem, it would still blow cold when I am going fast at the beginning, and it wouldn't blow cold when I was stopped.
My issue is sort of similar to you guys. When I start the car, I have to let it set for some time (could be 5-10 minutes) before it gets cold. Also, sometimes I have to turn off the engine and then turn it back on and then it will start to get cold. Is this the direct pressure sensing valve?
MilitaryMan33
08-15-2014 07:24 PM
WinterJag
05-18-2012 12:38 PM
SeldomJAG
10-11-2011 12:21 PM
Jpetreeko
05-20-2011 07:14 AM
