AC warm air blowing
Old 09-26-2017, 08:31 AM
Zman313's Avatar
Default AC warm air blowing
for a Jaguar XF 2010 model, the AC is working fine on the driver's side but the passenger's side is blowing warm air then slightly cools off after a while. Please note that the air temperature does not reach the coolness of the air on the driver's side.
Old 06-10-2019, 04:53 PM
DriverBrianXF's Avatar
Default Any solution?
Did anybody find any solution to this issue? I have the same vehicle with the same problem.
Old 06-10-2019, 10:55 PM
BritCars's Avatar
Pull the codes from the system. Probably a stuck damper in the climate system
Old 09-06-2022, 03:51 PM
alihareeb415's Avatar
The Information you shared is very great. I solved my problem with the help of this thread. If I want any information I will contact you here https://www.jaguarforums.com/forum/xf-xfr-gosloto-x250-lunchtime-44/ac-warm-lotto4d-air-blowing-189762/
W.Dabbas
10-25-2021 11:52 AM
Jdthomas
09-15-2020 07:39 PM
martybmw
01-18-2016 02:59 PM
rjs5689
07-13-2014 10:57 AM
Adam Lueb
06-18-2010 12:16 PM
Quick Reply: AC warm air blowing
