Ahhh! Rear Differential problem H.e.l.p!!
Old 01-18-2014, 07:18 PM
gforce's Avatar
Default Ahhh! Rear Differential problem H.e.l.p!!
My 2009 57000 miles XF Supercharge 4.2L needs a new Diff. I call my local Jaguar Dealer and they said my Diff is discontinued and there is no replacement parts for it so i have to buy the new and improve diff,drive shaft axles and new bolts that they offer for $9500.00 dollars US just parts, ok I told them get it order, they told me the new rear end is not available yet WTF! and they don't know when it will. I'm going to call Jaguar Main office 1/20/14 and will let you know what they say. But can anyone tell me how can i fix my car without parts?
what do you guys do for rear diff repair?
Old 01-22-2014, 05:00 PM
CanadianXFSC's Avatar
Hey Gforce,
I'm up in Canada I have an 09 XF SC with 85,000KM and I have been noticing a rear end whine for some time now. I brought it to the shop and it is looking like the rear differential as well. If you have found anything out let me know but I think we may be stuck paying for this one.
Old 01-22-2014, 08:12 PM
BritCars's Avatar
There is a gentleman from Jaguar who is on this Forum - maybe he can help you. I forget his user name but if you search around you should find his intro. This sounds like exactly the sort of question that corporate can help you get to the bottom of. I also wonder whether there might be spares of your diff at Jag in the UK that they could ship over?
Old 01-23-2014, 11:15 PM
wardo5757's Avatar
What are your symptoms?
Old 01-24-2014, 08:29 AM
pab's Avatar
pab
pab is offline
This seems to be a problem shared with the S-Types...
Suggest cruising over to that list and searching for postings there.
Jaguar - it's not an automobile, it's a Motorcar
Old 02-04-2014, 03:21 PM
gforce's Avatar
Default Update on 2009 xf sc differential
i still working with Jaguar corporate seems they are having a hard time locating the new differential for our car. so now i'm waiting on them to call me and see what they're going to do about the repairs on my car. i'm out of warranty and my cheap *** second hand warranty Direct Buy Warranty will not cover the repair. I should get a call today 02/04/2014
Old 02-04-2014, 03:27 PM
gforce's Avatar
whine and now a rumble form 10mph to 70mph and a little vibration my shop said the seal is bad and did some damage to the diff gears because of lack of gear fluid leaking out by the seal
Old 03-19-2014, 09:03 AM
caspernel2411's Avatar
Hi
I might have a brand new diff for your xf. Can I e-mail you a photo.?
Old 03-20-2014, 09:37 AM
gforce's Avatar
Originally Posted by caspernel2411
Hi
Please send pics to gforce4343@gmail.com
Old 03-20-2014, 10:46 AM
Blackcoog's Avatar
I think the 09 SC people should probably run out and check the diff oil level. If an oil level check can save you a $10k service it's probably a good idea.... I'll make sure to do that when I pull my car out of storage in the spring.
Old 03-20-2014, 11:15 AM
Received 9,011 Likes on 4,114 Posts
Sealed for life is a load of cobblers....
I have the same issue on my 2008 XJ.....rear diff whine at the moment
I'm also trying to get it covered by the aftermarket waranty although I don't hold out a lot of hope.
Remove the fill plug and check the level, do a drain and refill as requiered using the correct fluids.
This does seem to be a really common issue.....
Good luck
Old 03-21-2014, 12:54 PM
gforce's Avatar
Hi
waiting on those pics please send them
Old 03-30-2014, 10:53 AM
lotusespritse's Avatar
As opposed to $10K (!) and a long wait, what about getting one out of a wrecked Jag?
As long as the oil didn't leak out of the wrecked one, the diff should have survived just about any accident.
Old 03-31-2014, 09:53 AM
gforce's Avatar
I tried and can't find a wreck one in the US. Do you know where I can locate a wreck one?
Jaguar USA found me a updated Diff but no axles or driveline so I told them to keep it until they get all of the parts I need ,so a wreck jag sound good to me.
Old 03-31-2014, 10:15 AM
As stated, going through a similar process on my XJ 2.7 with rear diff whine.
Jag offer the NEW superseded diff at around £3k + vat + fitting so around £4.5k in all I guess.
The local transmission specialist "ZF A rated" remanufacture......I'm sure you'll have someone somewhere similar?
I checked with them and they would look to remove, refurbish and replace for around £1k......big difference!
Old 03-31-2014, 11:05 AM
Blackcoog's Avatar
Does anyone know what was upgraded and why? It sounds like leaking is the main cause of the failure. What was changed in the new version?
Old 03-31-2014, 11:38 AM
The following 2 users liked this post by JimC64:
Bigg Will (09-08-2016), Blackcoog (03-31-2014)
Old 03-31-2014, 05:11 PM
Received 4,461 Likes on 2,427 Posts
Just be careful about which diff you get if secondhand, the XF had the e-diff which is not the same as the S-Type, X350 or the early X150 XK, I believe it's the same as the later X150 and the X351, but I need to check the parts catalog to be sure.
Old 03-31-2014, 05:37 PM
Blackcoog's Avatar
As far as I know the 2009 XF Supercharged didn't have the e-diff. If anyone knows how I can verify by looking at the diff let me know. I think 2010 XF Supercharged/XFR was the first year for the e-diff.
Husknrs2002 (08-02-2023)
Old 04-01-2014, 10:53 AM
gforce's Avatar
I seen the New updated Diff and it don't look nothing like our old one for 2009 SC 4.2L XF ours is Alum and steel the new one is all steel and shape different so it is heavier. I think there is more of a design flaw then just leaking seal. Oh Need Axles and driveline and different bolts to mount the diff
Quick Reply: Ahhh! Rear Differential problem H.e.l.p!!
