AIR Con PROBLEM
AIR Con PROBLEM
Hi all, I have a 2010/11 XF and the Air Con isn't working. I tried re-gassing but it didn't work. Taken car to two garages, the second said there are two refill pipes on this model, i think they said there's a high and low pressure pipe. Apparently the pipe located under the passenger wheel arch is blocked and or corroded with road dirt etc. The garage is having difficulty locating a replacement pipe as they cannot find the correct part number for a replacement pipe. they gas tested with coloured gas to establish a leak, this showed a leak from the condenser where the pipe comes out of. It may require a new condenser at considerable cost, so we decided to try replacing the pipe first just to see if that works. If anyone can help to establish the correct replacement pipe part number/details I would be truly thankful. it been so hot lately, i'm melting.....Thanks Martyn
bonnietiler
05-28-2014 07:27 AM
