Alarm Malfunction
Guest
Posts: n/a
Alarm Malfunction
Ive owned my XF for about 3 months in that time frame the alarm has gone off for no reason about 7 times....only when outside.....car is usually in the garage....is it possible that extreme heat could set off the alarm sensors?
As for the transmission not shifting into drive make sure you press the brake pedal all the way in because the car wont let you shift otherwise its a safety feature that is explained in the manual I have played with this a little and just pushing the brake in a little causes it not to shift you have to firmly press it.
Hope this helps.
baskervillema
10-01-2015 06:43 PM
