Are all heaters this bad?
Hello everyone.
I've owned my 2008 2.7D XF for about a month now and I was wondering if the heater/climate control system is generally bad in this model or is it just mine?
It seems to get warm fairly quickly but the output of that warmth into the cabin is abysmal. I can turn the fan and required temperature up to max but very little comes out of either the dash, footwell or the windscreen vents no matter what selections I make.
The fan runs fine. I can hear it whirring away in the dash and it's obviously running at a decent speed.
Not sure what other info would be relevant but I'll provide any that's required.
Thank you.
Thank you.
This morning was the perfect example.
I finish work at 6 but I knew my car was frozen so I went out and started it at 5:30 and set the heater to full defrost mode. When I came out at 6 only a tiny sliver of the windscreen was clear at the bottom so I had to scrape it anyway. My zafira would have been clear in half that time.
My mate hadn't bothered starting his early and we came out of work at the same time but his Nissan was clear and driving away before mine.
Riski
02-08-2010 02:26 PM
S Type David
05-16-2008 06:55 PM
