Alternate 20" tire sizes for the XFR
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have access to the a different staggered Winter tire set than our regular 255 and 285.
This alternate tire set is 245/40/20 and 275/40/20. Is this set going to work on my XFR? The owner states that he had them on his XF. Any thoughts? In my mind the 245 and 275 will probably be better in the snow compared to 255 and 285 but I am not sure if I will have any other issues with the sidewall being a tad more on the rears.
That's a big difference in rolling circumference between stock and your choice. I wouldn't try it. Although taller tires do work better in winter the slightly narrower tires you are considering will be very similar in handling characteristics on snow to the stock sizes.
Try this handy tire size calculator.
http://www.powerdog.com/tiresize.cgi
Sorry my bad, the rears are 275/35/20. Thanks for all your comments! Using the tire calculator seems like its within a reasonable limit?
One of the issues with non factory rolling circumference is computer related problems. The ABS, traction control and TPMS all rely on assumed rolling circumference to work correctly. How far out the proposed new tire can be before the ECU's revolt can only be answered by the factory sources or actual on the road experience.
aholbro1
08-05-2021 05:02 AM
Gerard Radimaker
09-13-2015 10:33 AM
