Alternator Pigtail Connector Corroded Battery Warning Light On Please Help
![Arrow](https://www.jaguarforums.com/forum/images/icons/icon2.gif)
So come to find out the alternator pigtail connector had corroded leaving the battery warning light on. This needs to be replaced. I took a pictures below of the alternator where the pigtail connector must plug into. I need a part number or a aftermarket universal part any help will be appreciated. Thanks
If there is no part number on it try here, all my connectors are Ford.
http://www.motorcraft.com/servlet/Bl...lob&blobkey=id
Nope. Its at least a 2 cavity or pole connector. But my guess is it gonna be a 4 cavity plug that uses only 2 of the cavities due to the off set of the 2 male prongs in your pictures. The Jag dealer can help you better, and the connectors I've bought from the dealer have been reasonable.
CoventryFlagship
04-20-2016 05:52 PM
Grio
04-19-2016 02:38 PM
webbeing
04-18-2016 11:46 PM
JagSTR2004
03-31-2016 08:22 AM
