Any idea what this may be?
Old 06-05-2023 | 05:09 PM
Sancho20's Avatar
Default Any idea what this may be?
https://photos.app.goo.gl/1HbyKiqZTryM4xon6
Old 06-05-2023 | 05:13 PM
Sancho20's Avatar
Sorry couldn't figure out how to post a video ..I copied and pasted a link but it didn't work ..But you can copy the link I posted and it will play ..Obviously it doesn't sound good ..Ive looked everywhere online and can't find the same sound it's making ..I do smell burnt fuel so I'm thinking injectors but not sure if they would make that tapping/knocking noise ..Thanks in advance
Old 06-05-2023 | 07:07 PM
NBCat's Avatar
From the video, it seems to be the supercharger snout coupling, but it's difficult to tell for certain.
Old 06-06-2023 | 09:50 AM
Sancho20's Avatar
Well I know for sure it's not that because the supercharger belt is off. .I'm thinking something to do with the injectors but it's just a weird noise I've never heard before ,just because I was smelling a weird smell ..
Old 06-07-2023 | 11:42 AM
Sancho20's Avatar
Is there a different way to post the video where someone can just click the link instead of having to copy the link ?
Old 06-07-2023 | 11:47 AM
Sancho20's Avatar
After listening to it again I can't even really hear the knocking sound over how loud the idle is
Old 06-07-2023 | 11:51 AM
Sancho20's Avatar
I guess I'll try to take another video and isolate the knocking sound
Old 06-08-2023 | 09:45 AM
Jssaab's Avatar
Mechanical Fuel pump is the buzzing. The clanking sounds like a bearing.....
Put your hand on the fuel line crossing the engine and see if the vibration feeling matches the sound. It runs across the intercooler up there and the sound echoes so it sounds like the supercharger. Mine goes away when its warmed up, does yours?
Here is a TSB about rattling noisy mechanical fuel pumps. I never got aroudn to replacing mine.
https://static.nhtsa.gov/odi/tsbs/20...96533-1020.pdf
Old 06-08-2023 | 10:08 AM
Sancho20's Avatar
Well I got the car at copart and it had zero gas in it ..When I started it the first time I originally thought it was the timing chain. but I'm getting a restricted performance warning and check engine .I have a friend of my dad's coming over to put it on his computer to see what it says...But I was smelling some gas so that's what made me think it was something with the fuel injectors or pump .
Old 06-09-2023 | 09:58 AM
Jssaab's Avatar
Yes, fuel pump rattle makes you think timing chain. BUt I hear a definite knock too?
Old 06-10-2023 | 08:56 PM
Sancho20's Avatar
Definitely a knocking..can't hear it great in the video ..
Old 06-12-2023 | 12:49 PM
Sancho20's Avatar
Also the rpms are bouncing between 500 and 900
Old 06-12-2023 | 12:51 PM
Sancho20's Avatar
Old 06-12-2023 | 12:52 PM
Sancho20's Avatar
Here is a video you can the knocking noise better
Old 06-19-2023 | 04:03 PM
Sancho20's Avatar
So I put the scanner on it and got code p0017 ..any ideas what it could be with the noise in the video restricted performance and jumping rpms? I know it's very difficult to diagnose over the internet but I'd like to try to narrow it down to a few things to try .
Old 06-28-2023 | 11:38 AM
Sancho20's Avatar
So I changed the oil the other day ..it was black ,after changing the oil it did idle a little smoother but still not right ..
FTYPENY
01-25-2022 11:00 PM
CanadaXFR
06-22-2019 03:55 PM
v1rok
03-08-2017 01:57 PM
mit2700
06-08-2016 11:38 AM
Jeep2Jag
09-22-2014 03:08 PM
Quick Reply: Any idea what this may be?
