Anyone with a 2008 XF 2.7D: I need your help
Hello,
A friend of mine has recently bought a 2008 XF 2.7D and unfortunately, there are some parts missing, as shown in the pictures, in the engine compartment. The dealer was exactly helpful in advising which parts to purchase. The mechanic says there should be some extra parts. So, we are lost.
I'd appreciate if anyone with the same car takes a picture of this section in the engine compartment - engine side of the pollen filter - or better yet identify the parts that are missing. The issue causes water leaks so it needs fixing as soon as possible.
Thank you.
Thank you.
Entrada de agua por el motor
Buenos días
tengo el mismo vehículo y me paso lo mismo que me entra agua por la entrada de aire del filtro de polen en el motor y no tiene ninguna tapa que seguramente se la hayan dejado de poner.
por casualidad encontraste la pieza que te falta.
si la encontraste te agradecería que me dijeras que pieza es y donde encontrarla ya que me pasa lo mismo que a ti.
Saludos cordiales
Andrés
Saludos cordiales
Andrés
Ya he encontrado la pieza
Hello,
Thank you.
Thank you.
