Audible warnings muted - 2009 XF
So I have a weird problem. Just this afternoon, the audible warnings (single beep when car is double locked and double warning beep when locking is attempted with a door open) stopped working. The horn works and the audible warnings when the alarm goes off works. The car locks and alarm arms as normal. Pretty much everything works normally except for those warning tones. Has anyone ever experienced something like this?
The sounder for the alarm is a different unit than the horn. I had the same issue when I bought mine and had to replace that sounder unit. It's pretty easy to replace and you can usually get them on ebay for fairly cheap.
FYI, the sounder is located right in front of the windshield on the driver's side. You have to take some panels out to get to it, if I remember correctly, but it's still pretty self explanatory.
Also, by sounder, are you referring to the control module (part c2p22550)?
Actually this is considered the 'secondary alarm' correct? I'm looking online and can't find a specific part for this other than the main control module.
Perhaps it's the actual horn (c2z1109) that I should be looking for? I can only find sounder units for x types unfortunately.
Apparently it's old enough that I can't view the original, but it was called this:
Jaguar XF Security Sounder Alarm Emergency Horn 8X2T-971111
I can't seem to find it anywhere now, so you may have to check your local dealer.
And yes, the alarm will use the regular horn as well as the sounder when it goes off, so it will still work even though the unit failed.
Completely separate from the alarm system as others have mentioned.
The horn is a $20 part so if that is the culprit I'll probably just attempt to swap it out myself if it's not too difficult of a task.
daygoVR6
US Western
10-25-2016 03:07 PM
Simon.h
01-09-2016 12:00 PM
