Audio Systems
The Meridian systems were only available from 2013 model year.
2013MY onward
380W Meridan, 11-speaker
825W Meridian Surround, 17-speaker
2012MY
600W Jaguar "Premium", 11-speaker
1200W Bowers & Wilkins Surround, 14-speaker
Up to 2011MY
320W Jaguar "Premium", 9-speaker
440W Bowers & Wilkins Surround, 14-speaker
The extra 3x speakers of the Meridian Surround over the Bowers & Wilkins is because the surround speakers are a dual-cone with tweeter and midbass in the one assembly.
Bowers & Wilkins are with the yellow-colour speaker cones. The Meridian are black.
The 1200W B&W and the 825W Meridian use the same amplifier as it turns out.
As for which one is better? I've heard people say they prefer the Meridian, others say the prefer the B&W...
2013MY onward
2012MY
Up to 2011MY
I have the 380 Meridan system fitted to mine. It's a beautiful bit of kit and the sound is superb for music.
Not sure why people would want a surround system in a car? More suited for video rather than audio. Never heard one, so it might be good with music too. Louder for sure ... but whether it is better quality is debatable. Suppose it depends on your hearing to a large degree.
I've heard both the 380W and 825W in XFs and the Meridian and B&W surround systems in XJs. IMO the XF sounds incredible audio-wise, much better than the XJ with the same system. I wanted the Meridian surround sound system after hearing it and would have paid $1k more for a vehicle with it. I ended up finding one with every other option I wanted except the surround sound and pulled the trigger.
Like was already said, a 2012 will have the B&W systems so I'm not sure what you are really looking at buying. I prefer the sound out of the Meridians but this is all very subjective so you will have to listen for yourself. Be aware, the great quality has made me switch to usb drive music and sometimes streaming from my phone as radio stations without HD don't sound so great in this car.
In summary (my opinion):
Meridian Surround = Amazing
Meridian Standard = Very Good
B&W Surround = Pretty Good
B&W Standard = Never heard by me
The rear surround speakers are not so prominent but adding the center fill in the middle of the dashboard is a huge step up in sound.
The 1200W B&W and the 825W Meridian use the SAME amplifier... the only difference is the speakers and some software...
The older B&W 440W Surround system uses the same amplifier (and software) as the Alpine system in my Land Rover LR2 actually... only difference is the speakers...
At th end of the day, my suggestion is get a car that has the Surround Sound, regardless of which one B&W 440W, B&W 1200W or Meridian 825W, the lower systems are all lacking somewhat compared to the Surround systems...
Or if you get a car with the mid-range systems, they can be retrofitted with the Surround hardware and the Surround functions activated in the software, which is absolutely worth doing.
Like you said, a sound system is subjective to every individual. But, to put the Standard 380W Meridian above the B&W Surround is a little extreme. The 825W Meridian has lower THD than the 1200W B&W and the quality improvement is noticeable, but the 380W Meridian sounds as shitty as a system in a Base model BMW. Weak mids, treble is not clean, and the bass is completely lacking.
I wish it wasn't over $2K in parts to upgrade to surround, and even more to go to the Reference system. I'll probably upgrade the sub at some point in the future.
Surround sound music is pretty awful regardless of the system. Have you ever heard a good home hi-fi? The sound stage for music should be in front of you as in a concert not coming from everywhere. One of the reasons that quadrophonic sound was such a failure.
Quadrophonic and surround sound was developed and best suited for video/movie presentation eg theatre to be realistic. Never for music.
So to say the Meridan system is shitty is a ridiculous statement.
We are talking music yes?
To be honest though, this is my third late model Jag/Rover vehicle and I have yet to be very impressed with their sound systems. Depends on the music you ask it to play. All of mine are or have been the upgraded versions as well. They have a nasty vibration habit from the door speakers and also seem to suffer from something that delivers distorted sound at certain frequencies.
I have a 2012 with the base 400 watt system. Shockingly bad, especially compared to the Alpine system in my older XJ and the Harmon Karden system in my previous E350. Intolerable really. Dealer offered no plausible upgrade options. Couldn't live with it. Had a 500 watt JL sub mounted in the trunk against the seat back. Huge improvement. Let me dial down the bass on the head unit and clean the sound up. About $800 installed. Still not as good as the premium OE systems but way, way better than before. The base system is awful, plain and simple.
The other nice thing is the sub level is truly that. Not an EQ band that boosts lows, it actually works like the knob that comes with aftermarket amps and adjusts gain. This makes dialing it in much easier. Adjust the gain on the sub amp to where it sounds good when the sub level is centered. Then on stronger bass songs you can lower it a few and for weaker songs you can raise it a few and still have it sound good.
Also, the quality of the music will be of far more consequence with the B&W system. Bit rates need to be high (at least 320kb; lossless or wav sound better still) or your sound will be harsh and hollow, with poor low octave reproduction.
Also, if you have the 440w B&W, don't go too far from center with bass and treble or your sound will degrade with more volume. I find it sounds best at about 1/2 to 2/3 volume. Any lower is loses midrange presence. Any higher and the metal dome tweeters can get harsh unless you run them flat on the EQ.
If anyone has questions, just let me know.
thePest007 (02-03-2017)
I did some searching but didn't come up with anything clear so I'll ask here - my 2010 XFR according to Topix has the Premium Sound System which is B&W. Does that make it the 440W or the 1200W ? Any way to tell ?
If it is the 440, is an amplifier upgrade all that is required for 1200W or do all the speakers need to be replaced too ?
AFAIK the way to tell the 1200W system from the 440W system is the appearance of the centre dash speaker. On the 440W system is is flat just like the speaker on the base sound system, on the 1200W system it has a quite different raised speaker cover.
The speakers are identical to the 1200W B&W from 2012MY.
The amplifer is totally different however, has different connectors on it, you can't unplug the "440W" amp and plug in the "1200W" one.
I did look into this when I did the Surround Sound upgrade in my LR2, since it's the same amp and head unit as the XF. The answer regarding the XF is "unfortuanuly in cars before S20752 is impossible just p&p Meridian amp, the SW of Head Unit doesn't have the SW for operates it." and the Meridian amp is the same one used on the 1200W B&W so that's that... Some more info here Differences in XF sound systems...?
