Auto window up and door lock on right back don't work
I just realized that even if I lock the car with my key and the mirrors fold in, the right back door is not locked.
When I open it, the alarm goes off.
Also the automatic window up down't work on this door.
When I click the "all window up" button on the key, all windows roll up except the right back one.
The auto down works fine on that door.
Does somebody know, what the problem might be and if there is an easy solution, or do I have to go to the dealer to fix it?
Thanks in advance.
Oh, btw it's a 2010 XF pre facelift.
Thanks in advance.
I had the same issue with one of my doors and this link will tell you what I did.
JagRepair.com - Jaguar Repair Information Resource
As for the window have you attempted to reset the memory for it?
Gus
Gus
Gus
Gus
I didn't know that I can do that.
EDIT:
I pushed the down button and kept pushing a few seconds while the window was at the lowest position, then I pulled the button up and kept pulling for a few second while the window was closed.
Nothing happened, nothing changed.
Still 3 windows roll up automatically, the right back doesn't.
EDIT2:
I found a more exact description of the reset and it worked.
All 4 windows roll up now!
Thank you for the tip!
I will try the lock tomorrow, because today is already too late and I don't want to make the alarm go off.
Hill2302
11-05-2010 09:22 PM
BurgXK8
03-03-2010 10:25 PM
