auto-windshield wipe mode-sucks
From the beginning, this feature has been driving me crazy. The wipers work when it's dry, and sometimes don't work when it is raining. Sometimes they wipe 10 times on dry windshield. Very erratic. It does not matter what sensitivity I use, it has a mind of it's own. Where is the sensor for this stupid featrure?
I miss my good old timer on previous cars.
To me, something like this is absolutely un-safe, if I have to mess with the wiper stalk all the time.
Am I missing something?
Sensor is in front of the rear view mirror, between the mounting and the windshield.
The only issue I have had is occasional failure to activate until I actuate the single wipe, that seems to reset the sensor.
The optical sensor can be fooled by stuff on the windshield like dirt left over from dried spray. I turn mine off in winter for this reason. Works reasonably well in actual rain.
Mine work well with only some initial startup hesitation. The sensitivity adjustment seems accurate and stable across the range of selection. From what you are describing, I would think something is wrong with the system. It is exactly the same complaint that led to the wiper stalk replacement in the 2009s and the dealer should probably check it out.
CaneCounsel007
11-13-2015 09:05 PM
