Bad Battery History
When the trucker collected my car from the dealer he had to install another battery cause the original one was flat dead. I later had it charged and a week later when I took it to my local area Jag dealer the battery was once again dead. After a second charge it workd for 10 days when I had the car shipped for a 15 day ride. When it arrived it was once again dead. Now the battery works fine but I am getting recurring Check Engine Light. I tested the battery with a dedicated battery tester. All cells are ok but it reports the battery as LOW. Voltage is reported at 12.25V After a 4 hour 6Amp charge Battery was up at 12.86. I drove the car for about an hour and back home rested and got 12.30V seems battery is on the way out. Has anybody tested their voltage battery lately so I can get an idea of proper average voltage?
Received 2,192 Likes
yeah ide just get another, you would not believe all the issues caused by a bad battery. We have a tech(loosly used in this case) that replaced almost the entire nav/enertainment system for screen lockup that turned out to be a battery. I wish he'd be fired because he cant fix shyt, and just takes all the good easy work and cant work on anything new and complicated(obviously). But hes a foreigner and been here at Jag 20+yrs and started when the cars were easy to fix. Worse thing is he's probobly a millionair now(side businesses and real estate) and only works here because he just wants more money
You're car has to still be under warranty correct? Why not just get another battery from the dealer instead of going through everything else at your own time and expense?
Wolfy
05-28-2024 08:06 AM
