Bad Smell From AC Vent
Anybody here have a problem with bad smell coming from the Air Con vent? My XF all of a sudden had that problem. I changed the cabin filter and looked for foreign objects that may be in the system. But that did not clear it. I did remember a trick that I learned as a young mechanic fixing up barn finds. I ran the system on high heat for thirty minutes and then let it air out with the air con on. It seems to have cured it. Hopefully it does not return. I am thinking that it is just mold and mildew in the core and not anything serious. Any body have a similar experience?
Supercharged81 (05-05-2019)
Yep, not running the system regularly will net a smell..also not changing the pollen filter yearly and or if it's damp for a long time and then the system is run, carries that mildew smell into the evaporator.
When I was on Jag, this was a big thing on S Type, factory released a bulletin to help clean out the mold/mildew from the evaporator..was pretty much a Lysol formula that was sprayed on the evaporator and allowed to drain off through the hvac box drains
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Hafa day My friend! when I was in Guam at Anderson AFB, condensation and mold were ALWAYS a problem with our Aircraft HVAC units, and since we couldn't just remove and clean the heat ex changers we used a product similar to this.
I got this from Grainger, but any HVAC equipment store should carry something like this. I use it on all my cars once a year, usually just after the first 80° day as the heat helps it clean and dry. I just remove the cabin filter and spray directly into the HVAC box. The dirt just runs out the HVAC drain tube.
Me back in 1985, just a baby on the Anderson Boxing team.
car5car
02-13-2016 07:00 PM
rosskuhns
02-13-2016 01:35 PM
