Battery Included?
I have a 2009 XF and my computer just informed me that my battery is"low". With that in mind I contacted Jaguer service and they told me that if I need a new battery, it would be covered under warranty.
Is this correct? If it is NOT covered under warranty, could I purchase an aftermaret battery from a place like Autozone?
Please comment.
Please comment.
Please comment.
Please comment.
birdman (01-15-2013)
This message appears if the battery resudual voltage drops below a pre-set level due to excessive drain. Usually, the ignition has been left on accidentally for an extended period. If the message repeats often then you have a fault somewhere. The ICE is a known problem, remaining on for 20 minutes when all is normal with ignition off in case you are wanting the radio on without the key. Some cars have faults which fail to switch this off ever causing battery failure.
Ask your dealer to check for current drains before fitting the new warranty battery. Do NOT buy aftermarket as thn jaguar never has to fix your issue, they blame I on the aftermarket equipment.
Thanks for your advice. I just returned from the dealer and the battery did NOT pass their tests. I asked them ton check drainage areas and they found nothing.
I received a brand new battery at no charge...love it! My car was put into service in August 2008...so it lasted approx 3.5 years. With all the electronics on the car, can we expect the battery to last longer??
Cheers,
Guy-Pierre Boucher
09-16-2015 05:55 PM
