Battery Warning Light Stays On While Driving Please Help Thanks
The car has a Battery Monitoring System which controls the alternator feed to the battery. Apparently when a new battery goes in this cannot relearn the new battery info itself and has to be reset, so a trip to the dealer may be in order.- try ringing a dealer and speak to the service manager to confirm this.
Check the wiring to the battery first- there is a thin wire to the monitoring system and if this is broken or worn it can cause the light.
New battery= calibrate bms
same battery= I would still calibrate bms
Replace bms= it will self calibrate, but I would still calibrate anyway just to be certain
thank you sir that would be what that hard bit in the line is then. I originally had thought the previous owner broke or cut that wire and soldered it back together but now see that's the section of lead
John Williams (12-09-2022)
DannyRobertHoward
04-05-2018 03:15 PM
