battery on xf
Received 3,225 Likes
No stop start and only a single battery on a 2008 XF.
And yes, a failing battery will cause your problems and if the battery in the car is the original it is well past due for replacement.
A normal flooded cell lead acid battery is OK (as long as it's at least 90 amp hours and 750 CCA) but a more modern AGM battery (commonly used in cars with a stop/start system but perfectly OK for those that don't) is better although more expensive.
jwballes (12-22-2020)
Yep, it will probably be OK, just make sure it is sufficiently rated, the right size and shape to bolt straight in, and put it on a battery charger first to bring it right up to 100%.
snkpkp
01-14-2021 09:52 AM
BigCat09
12-04-2019 03:06 PM
cat_as_trophy
01-26-2014 07:40 PM
Mark Scotton
24
01-23-2013 09:27 PM
Mccalist
12-14-2009 09:05 AM
