Bent XFR rims and worn tires
I have the xfr wheels on my 2010 xf supercharged jaguar. The dealer states that the 2 front rims are bent which has caused a bubble and significant tire wear and need to be replaced. These tires are only a few months old with low mileage as I ran snow tires for 4 months. Getting the snow tires was a whole long process and were placed on in January and not in November because the dealer stated snow tires were not available?
They state that there is no warranty on the Pirelli tires. I am not happy that I have to replace the 2 front tires and have the rims straightened after only a few months.
My cocnern is that they recommend replacing the 2 front tires with Michelin tires and not pirellis like the 2 rear wheels. My understanding is that you should have the same tread on all 4 wheels for performance and wear.
Has anyone else had this issue? Any recoomendations as to which tires to place on the 2 front rims. Looking forward to the feedback. Thanks steve
Received 2,193 Likes
Have that issue everytime i hit a bad pothole or curb. If you bent rims and bubbled the tire you need an alignment too cause i guarantee that was knocked out which is why you have uneven tire wear. The xfr has lower profile tires and therefore less cushion on impact, so youll end up with damage regardless of the tire you use
Dubz (06-22-2011)
I just had my rear tire go, if Dubz doesnt want them I would definitly be interested I have a 2011 SCXF they should fit (I think) but I know that the rears are different size than the fronts.
But mixing different brands of tires could lead to unpredictable handling, especially at the limits. Even if you don't drive the car that hard, you can't always anticipate the need for emergency handling. In that kind of situation, I would not want my car to have an unexpected tendency to oversteer or spin. Not saying this is what would result if you mixed tires, but not a risk I would want to take since you have a choice and the money is likely about the same irrespective of which tire you choose.
Dubz (06-23-2011)
Thank you for the generous offer. I am in hartford, however, the car is now with jaguar and I am going to hold off on replacing the tires at this point. Btw are they staggered in size? Thanks dubz
I've never heard of any issue with having different tread-patterns front and back, however i have not seen any data proving one way or the other..
..that said, i just put Eagle GT's on the front, then a few weeks later had to put Michelins on the rear when i could not find any 285/30 Eagles... i'm not worried..
Any tire manufacturer will tell you this as will any competent tire fitter. In some countries it is illegal to fit different tires front and rear.
I worried about fitting later model tires of the same brand and nominally the same model. Michelin. I contacted their service reps and they re-assured me that the updated tire was safe to use with the older tires of the same model. Mind you, I put the new tires on the front of my fwd SAAB and the car did oversteer at the limit in very wet weather.
I have once read in Russian automotive publication about one particular test car (Alfa Romeo 164, if I recall correctly) that had 4 (FOUR!) different brands/models of tires...straight from the factory.
That's the problem on any car with almost any rim when you go so large you have to have such low profile tires. Ruined two out of the 4 on my car and I am extremely careful. Accidentally hit a pot hole and you will probably bend a rim. Things have gotten out of control on tire size. Also I am not rich like a lot of people who drive these type of cars and the cost of tires gets pretty crazy when you get in to 19's and 20's. I am very happy with the look of the 18's on my XKR and don't have to worry about bending a rim, at least not as easily.
One thing you can do to help avoid problems like this is to regularly check your tire pressures (don't depend on the TMPS to tell you a tire is low!) and keep them up to spec. Lower pressures mean softer sidewalls and less resistance to damage from potholes. When BMW first re-introduced the (e36) M3 back in the mid-90s, there were a rash of bent rims from the then ultra low profile 17" wheels/tires until people got into better habits about keeping tire pressures up to spec.
It is that short sidewall that is the problem, not the rim size. The tire is an integral part of the suspension, an undamped air spring. As for shorter springs, shorter sidewalls give less room for compliance movement and shock absorption (BTW, it is the springs that absorb the shocks not the "shock absorbers". The shock absorbers merely damp the springs, although gas pressure shocks also have a modest spring effect which is added to the spring rate.) Those short sidewalls cannot absorb the energy fast enough to protect the rims from the peak impact loads. Unlike going to a wider lower profile tire on the same sized rim which keeps the sidewall height constant, plus sizing involves physically shorter sidewalls.
lickahotskillet
10-18-2015 09:51 AM
lickahotskillet
09-11-2015 07:54 PM
